Time Before: 0.00833 seconds
Time After: 0.01089 seconds
Time Taken: 0.00256 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01098 seconds
Time After: 0.01136 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01162 seconds
Time After: 0.01173 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01245 seconds
Time After: 0.01519 seconds
Time Taken: 0.00274 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01179 seconds
Time After: 0.01918 seconds
Time Taken: 0.00739 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02382 seconds
Time After: 0.02422 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02688 seconds
Time After: 0.02829 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.02304 seconds
Time After: 0.02856 seconds
Time Taken: 0.00552 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.04917 seconds
Time After: 0.04930 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.07555 seconds
Time After: 0.07681 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.09395 seconds
Time After: 0.09412 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.09811 seconds
Time After: 0.09956 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=70008', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.11768 seconds
Time After: 0.11808 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
