Time Before: 0.00224 seconds
Time After: 0.00349 seconds
Time Before: 0.00357 seconds
Time After: 0.00409 seconds
Time Before: 0.00439 seconds
Time After: 0.00453 seconds
Time Before: 0.00535 seconds
Time After: 0.00798 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00461 seconds
Time After: 0.01140 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01326 seconds
Time After: 0.01367 seconds
Time Before: 0.01649 seconds
Time After: 0.01774 seconds
Time Before: 0.01269 seconds
Time After: 0.01799 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02710 seconds
Time After: 0.02722 seconds
Time Before: 0.03005 seconds
Time After: 0.03128 seconds
End call of global.php: 0.033665895462036
Time Before: 0.03614 seconds
Time After: 0.03630 seconds
Time Before: 0.03905 seconds
Time After: 0.04051 seconds
SET lastactivity = 1785337627, location = '/forums/private.php?do=newpm&explain=1&u=70046'
Time Before: 0.05353 seconds
Time After: 0.05385 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.052592039108276 seconds with 9 queries, spending 0.0082337856292725 doing MySQL queries and 0.044358253479004 doing PHP things.
