Time Before: 0.01590 seconds
Time After: 0.02012 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02023 seconds
Time After: 0.02064 seconds
Time Before: 0.02087 seconds
Time After: 0.02134 seconds
Time Before: 0.02223 seconds
Time After: 0.02645 seconds
Time Before: 0.02140 seconds
Time After: 0.03193 seconds
Time Taken: 0.01054 seconds
Time Before: 0.03775 seconds
Time After: 0.03814 seconds
Time Before: 0.04061 seconds
Time After: 0.04192 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03706 seconds
Time After: 0.04213 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.719 KB
Time Before: 0.06850 seconds
Time After: 0.06864 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08055 seconds
Time After: 0.08179 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.084381103515625
Time Before: 0.08923 seconds
Time After: 0.08941 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09186 seconds
Time After: 0.09334 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=7006'
Time Before: 0.11234 seconds
Time After: 0.11260 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
Page generated in 0.11095809936523 seconds with 9 queries, spending 0.010105848312378 doing MySQL queries and 0.10085225105286 doing PHP things.
