Time Before: 0.02141 seconds
Time After: 0.02933 seconds
Time Taken: 0.00792 seconds
Time Before: 0.02941 seconds
Time After: 0.03064 seconds
Time Before: 0.03084 seconds
Time After: 0.03096 seconds
Time Before: 0.03184 seconds
Time After: 0.03391 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03105 seconds
Time After: 0.03861 seconds
Time Taken: 0.00756 seconds
Time Before: 0.04915 seconds
Time After: 0.04961 seconds
Time Before: 0.05275 seconds
Time After: 0.05398 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04846 seconds
Time After: 0.05419 seconds
Time Taken: 0.00573 seconds
Memory After: 2,261.836 KB
Time Before: 0.07724 seconds
Time After: 0.07783 seconds
Time Taken: 0.00058 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.21755 seconds
Time After: 0.21885 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.22127294540405
Time Before: 0.22702 seconds
Time After: 0.22715 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.22974 seconds
Time After: 0.23124 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788990399, location = '/forums/private.php?do=newpm&explain=1&u=70123', badlocation = 1
Time Before: 0.25393 seconds
Time After: 0.25421 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.25250291824341 seconds with 9 queries, spending 0.0089049339294434 doing MySQL queries and 0.24359798431396 doing PHP things.
