Time Before: 0.01014 seconds
Time After: 0.01660 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01671 seconds
Time After: 0.01717 seconds
Time Before: 0.01741 seconds
Time After: 0.01757 seconds
Time Before: 0.01833 seconds
Time After: 0.02044 seconds
Time Taken: 0.00211 seconds
Time Before: 0.01764 seconds
Time After: 0.02544 seconds
Time Taken: 0.00780 seconds
Time Before: 0.03207 seconds
Time After: 0.03247 seconds
Time Before: 0.03503 seconds
Time After: 0.03625 seconds
Time Before: 0.03135 seconds
Time After: 0.03648 seconds
Time Taken: 0.00513 seconds
Time Before: 0.05598 seconds
Time After: 0.05618 seconds
Time Before: 0.06971 seconds
Time After: 0.07098 seconds
End call of global.php: 0.073240041732788
Time Before: 0.07765 seconds
Time After: 0.07783 seconds
Time Before: 0.08038 seconds
Time After: 0.08186 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=70162'
Time Before: 0.10081 seconds
Time After: 0.10121 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.099647998809814 seconds with 9 queries, spending 0.0078651905059814 doing MySQL queries and 0.091782808303833 doing PHP things.
