Time Before: 0.00137 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00246 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00268 seconds
Time After: 0.00289 seconds
Time Before: 0.00355 seconds
Time After: 0.00591 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00294 seconds
Time After: 0.01069 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01319 seconds
Time After: 0.01360 seconds
Time Before: 0.01631 seconds
Time After: 0.01824 seconds
Time Taken: 0.00193 seconds
Time Before: 0.01242 seconds
Time After: 0.01850 seconds
Time Taken: 0.00608 seconds
Time Before: 0.02651 seconds
Time After: 0.02685 seconds
Time Before: 0.02956 seconds
Time After: 0.03156 seconds
Time Taken: 0.00200 seconds
Time Before: 0.03473 seconds
Time After: 0.03509 seconds
Time Before: 0.03810 seconds
Time After: 0.04046 seconds
UPDATE session SET lastactivity = 1789119466, location = '/forums/private.php?do=newpm&explain=1&u=70199', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05502 seconds
Time After: 0.05555 seconds
Time Taken: 0.00053 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
