Time Before: 0.02609 seconds
Time After: 0.03074 seconds
Time Taken: 0.00465 seconds
Time Before: 0.03085 seconds
Time After: 0.03142 seconds
Time Taken: 0.00058 seconds
Time Before: 0.03169 seconds
Time After: 0.03184 seconds
Time Before: 0.03257 seconds
Time After: 0.03542 seconds
Time Taken: 0.00284 seconds
Time Before: 0.03190 seconds
Time After: 0.03946 seconds
Time Taken: 0.00756 seconds
Time Before: 0.04718 seconds
Time After: 0.04760 seconds
Time Before: 0.04884 seconds
Time After: 0.05002 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04646 seconds
Time After: 0.05028 seconds
Time Taken: 0.00382 seconds
Time Before: 0.08841 seconds
Time After: 0.08856 seconds
Time Before: 0.10697 seconds
Time After: 0.10821 seconds
Time Before: 0.11713 seconds
Time After: 0.11728 seconds
Time Before: 0.11951 seconds
Time After: 0.12094 seconds
UPDATE session SET lastactivity = 1776491276, location = '/forums/private.php?do=newpm&explain=1&u=70231', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.13876 seconds
Time After: 0.13906 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
