Time Before: 0.00342 seconds
Time After: 0.00469 seconds
Time Before: 0.00482 seconds
Time After: 0.00525 seconds
Time Before: 0.00546 seconds
Time After: 0.00560 seconds
Time Before: 0.00675 seconds
Time After: 0.00918 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00569 seconds
Time After: 0.01434 seconds
Time Taken: 0.00865 seconds
Time Before: 0.02048 seconds
Time After: 0.02095 seconds
Time Before: 0.02427 seconds
Time After: 0.02668 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01964 seconds
Time After: 0.02697 seconds
Time Taken: 0.00733 seconds
Time Before: 0.03644 seconds
Time After: 0.03658 seconds
Time Before: 0.03915 seconds
Time After: 0.04043 seconds
Time Before: 0.04549 seconds
Time After: 0.04575 seconds
Time Before: 0.04852 seconds
Time After: 0.05000 seconds
UPDATE session SET lastactivity = 1788972265, location = '/forums/private.php?do=newpm&explain=1&u=70262' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06598 seconds
Time After: 0.06647 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
