Time Before: 0.01946 seconds
Time After: 0.02711 seconds
Time Taken: 0.00765 seconds
Time Before: 0.02723 seconds
Time After: 0.02779 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02808 seconds
Time After: 0.02820 seconds
Time Before: 0.02900 seconds
Time After: 0.03117 seconds
Time Taken: 0.00217 seconds
Time Before: 0.02826 seconds
Time After: 0.03522 seconds
Time Taken: 0.00695 seconds
Time Before: 0.04488 seconds
Time After: 0.04532 seconds
Time Before: 0.04764 seconds
Time After: 0.04892 seconds
Time Before: 0.04420 seconds
Time After: 0.04911 seconds
Time Taken: 0.00491 seconds
Time Before: 0.08965 seconds
Time After: 0.08982 seconds
Time Before: 0.10962 seconds
Time After: 0.11088 seconds
Time Before: 0.12496 seconds
Time After: 0.12512 seconds
Time Before: 0.12780 seconds
Time After: 0.12923 seconds
UPDATE session SET lastactivity = 1776811024, location = '/forums/private.php?do=newpm&explain=1&u=70561', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14981 seconds
Time After: 0.15016 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
