Time Before: 0.00145 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00246 seconds
Time Before: 0.00271 seconds
Time After: 0.00283 seconds
Time Before: 0.00372 seconds
Time After: 0.00625 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00290 seconds
Time After: 0.01183 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01430 seconds
Time After: 0.01450 seconds
Time Before: 0.01748 seconds
Time After: 0.01866 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01352 seconds
Time After: 0.01892 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02500 seconds
Time After: 0.02513 seconds
Time Before: 1.00539 seconds
Time After: 1.00680 seconds
End call of global.php: 1.0096969604492
Time Before: 1.01085 seconds
Time After: 1.01099 seconds
Time Before: 1.01350 seconds
Time After: 1.01492 seconds
SET lastactivity = 1784745113, location = '/forums/private.php?do=newpm&explain=1&u=70578', badlocation = 1
Time Before: 1.03366 seconds
Time After: 1.03393 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
Page generated in 1.0325999259949 seconds with 9 queries, spending 0.0078749656677246 doing MySQL queries and 1.0247249603271 doing PHP things.
