Time Before: 0.01257 seconds
Time After: 0.01663 seconds
Time Taken: 0.00406 seconds
Time Before: 0.01674 seconds
Time After: 0.01716 seconds
Time Before: 0.01748 seconds
Time After: 0.01763 seconds
Time Before: 0.01864 seconds
Time After: 0.02120 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01771 seconds
Time After: 0.02547 seconds
Time Taken: 0.00776 seconds
Time Before: 0.03169 seconds
Time After: 0.03211 seconds
Time Before: 0.03556 seconds
Time After: 0.03675 seconds
Time Before: 0.03098 seconds
Time After: 0.03702 seconds
Time Taken: 0.00604 seconds
Time Before: 0.06296 seconds
Time After: 0.06311 seconds
Time Before: 0.07841 seconds
Time After: 0.07976 seconds
Time Taken: 0.00135 seconds
Time Before: 0.08859 seconds
Time After: 0.08875 seconds
Time Before: 0.09163 seconds
Time After: 0.09307 seconds
UPDATE session SET lastactivity = 1785423897, location = '/forums/private.php?do=newpm&explain=1&u=70654' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.11262 seconds
Time After: 0.11291 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
