Time Before: 0.02662 seconds
Time After: 0.03356 seconds
Time Taken: 0.00694 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03366 seconds
Time After: 0.03410 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03429 seconds
Time After: 0.03441 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03517 seconds
Time After: 0.03765 seconds
Time Taken: 0.00248 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03449 seconds
Time After: 0.04191 seconds
Time Taken: 0.00742 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05159 seconds
Time After: 0.05192 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05334 seconds
Time After: 0.05460 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05098 seconds
Time After: 0.05486 seconds
Time Taken: 0.00388 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09265 seconds
Time After: 0.09281 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.14691 seconds
Time After: 0.14814 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.15024900436401
Time Before: 0.17570 seconds
Time After: 0.17586 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.18105 seconds
Time After: 0.18246 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772693514, location = '/forums/private.php?do=newpm&explain=1&u=70796'
Time Before: 0.20755 seconds
Time After: 0.21198 seconds
Time Taken: 0.00443 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.20646691322327 seconds with 9 queries, spending 0.01201343536377 doing MySQL queries and 0.1944534778595 doing PHP things.
