Time Before: 0.02891 seconds
Time After: 0.03830 seconds
Time Taken: 0.00939 seconds
Time Before: 0.03842 seconds
Time After: 0.03897 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03924 seconds
Time After: 0.03978 seconds
Time Before: 0.04063 seconds
Time After: 0.04317 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03984 seconds
Time After: 0.04823 seconds
Time Taken: 0.00839 seconds
Time Before: 0.05569 seconds
Time After: 0.05609 seconds
Time Before: 0.05886 seconds
Time After: 0.06026 seconds
Time Taken: 0.00140 seconds
Time Before: 0.05511 seconds
Time After: 0.06043 seconds
Time Taken: 0.00533 seconds
Time Before: 0.10411 seconds
Time After: 0.10427 seconds
Time Before: 0.12904 seconds
Time After: 0.13026 seconds
End call of global.php: 0.13254809379578
Time Before: 0.13825 seconds
Time After: 0.13841 seconds
Time Before: 0.14129 seconds
Time After: 0.14274 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=70897'
Time Before: 0.16215 seconds
Time After: 0.17042 seconds
Time Taken: 0.00827 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.1612069606781 seconds with 9 queries, spending 0.016695022583008 doing MySQL queries and 0.14451193809509 doing PHP things.
