Time Before: 0.00785 seconds
Time After: 0.00991 seconds
Time Taken: 0.00206 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01000 seconds
Time After: 0.01050 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01074 seconds
Time After: 0.01093 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01174 seconds
Time After: 0.01425 seconds
Time Taken: 0.00250 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01100 seconds
Time After: 0.01769 seconds
Time Taken: 0.00670 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02068 seconds
Time After: 0.02089 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02307 seconds
Time After: 0.02429 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.02010 seconds
Time After: 0.02447 seconds
Time Taken: 0.00437 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.03532 seconds
Time After: 0.03621 seconds
Time Taken: 0.00090 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.05037 seconds
Time After: 0.05159 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.053210973739624
Time Before: 0.06161 seconds
Time After: 0.06178 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.06463 seconds
Time After: 0.06607 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=70943', badlocation = 1
WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.08476 seconds
Time After: 0.08512 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.083832979202271 seconds with 9 queries, spending 0.0087127685546875 doing MySQL queries and 0.075120210647583 doing PHP things.
