Time Before: 0.01523 seconds
Time After: 0.02186 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02195 seconds
Time After: 0.02241 seconds
Time Before: 0.02266 seconds
Time After: 0.02281 seconds
Time Before: 0.02360 seconds
Time After: 0.02586 seconds
Time Taken: 0.00226 seconds
Time Before: 0.02287 seconds
Time After: 0.03009 seconds
Time Taken: 0.00723 seconds
Time Before: 0.03704 seconds
Time After: 0.03728 seconds
Time Before: 0.03873 seconds
Time After: 0.03993 seconds
Time Before: 0.03624 seconds
Time After: 0.04013 seconds
Time Taken: 0.00389 seconds
Time Before: 0.06721 seconds
Time After: 0.06743 seconds
Time Before: 1.16478 seconds
Time After: 1.16641 seconds
Time Taken: 0.00163 seconds
End call of global.php: 1.1686728000641
Time Before: 1.17161 seconds
Time After: 1.17183 seconds
Time Before: 1.17449 seconds
Time After: 1.17605 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1772778809, location = '/forums/private.php?do=newpm&explain=1&u=70974', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 1.19517 seconds
Time After: 1.19541 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 1.1937408447266 seconds with 9 queries, spending 0.0082089900970459 doing MySQL queries and 1.1855318546295 doing PHP things.
