Time Before: 0.02193 seconds
Time After: 0.02866 seconds
Time Taken: 0.00673 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.02875 seconds
Time After: 0.02918 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.02940 seconds
Time After: 0.02951 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03033 seconds
Time After: 0.03252 seconds
Time Taken: 0.00219 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.02958 seconds
Time After: 0.03652 seconds
Time Taken: 0.00694 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.04495 seconds
Time After: 0.04536 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.04674 seconds
Time After: 0.04792 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.04435 seconds
Time After: 0.04811 seconds
Time Taken: 0.00376 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.08885 seconds
Time After: 0.08901 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.11742 seconds
Time After: 0.11864 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
Time Before: 0.13030 seconds
Time After: 0.13044 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.13309 seconds
Time After: 0.13451 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
UPDATE session SET lastactivity = 1777131716, location = '/forums/private.php?do=newpm&explain=1&u=71001' WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.15513 seconds
Time After: 0.15548 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
