Time Before: 0.00128 seconds
Time After: 0.00175 seconds
Time Before: 0.00182 seconds
Time After: 0.00371 seconds
Time Taken: 0.00190 seconds
Time Before: 0.00497 seconds
Time After: 0.00512 seconds
Time Before: 0.00585 seconds
Time After: 0.00801 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00519 seconds
Time After: 0.01142 seconds
Time Taken: 0.00624 seconds
Time Before: 0.01324 seconds
Time After: 0.01371 seconds
Time Before: 0.01686 seconds
Time After: 0.01803 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01257 seconds
Time After: 0.01829 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02507 seconds
Time After: 0.02520 seconds
Time Before: 0.02715 seconds
Time After: 0.02838 seconds
Time Before: 0.03150 seconds
Time After: 0.03163 seconds
Time Before: 0.03382 seconds
Time After: 0.03535 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=71087' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05056 seconds
Time After: 0.05077 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
