Time Before: 0.00127 seconds
Time After: 0.00170 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00178 seconds
Time After: 0.00240 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00269 seconds
Time After: 0.00286 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00353 seconds
Time After: 0.00630 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00291 seconds
Time After: 0.00969 seconds
Time Taken: 0.00678 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01143 seconds
Time After: 0.01188 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01436 seconds
Time After: 0.01558 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01081 seconds
Time After: 0.01577 seconds
Time Taken: 0.00496 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02052 seconds
Time After: 0.02069 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02267 seconds
Time After: 0.02390 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.025535821914673
Time Before: 0.02670 seconds
Time After: 0.02683 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.02881 seconds
Time After: 0.03026 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1785357007, location = '/forums/private.php?do=newpm&explain=1&u=71131', badlocation = 1
Time Before: 0.04583 seconds
Time After: 0.04613 seconds
Memory Before: 4,923.313 KB
Memory After: 4,923.523 KB
Page generated in 0.044927835464478 seconds with 9 queries, spending 0.0085365772247314 doing MySQL queries and 0.036391258239746 doing PHP things.
