Time Before: 0.03352 seconds
Time After: 0.04186 seconds
Time Taken: 0.00834 seconds
Time Before: 0.04202 seconds
Time After: 0.04243 seconds
Time Before: 0.04281 seconds
Time After: 0.04293 seconds
Time Before: 0.04375 seconds
Time After: 0.04613 seconds
Time Taken: 0.00238 seconds
Time Before: 0.04301 seconds
Time After: 0.05035 seconds
Time Taken: 0.00734 seconds
Time Before: 0.06049 seconds
Time After: 0.06090 seconds
Time Before: 0.06302 seconds
Time After: 0.06422 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05979 seconds
Time After: 0.06444 seconds
Time Taken: 0.00465 seconds
Memory After: 2,261.719 KB
Time Before: 0.12726 seconds
Time After: 0.12791 seconds
Time Taken: 0.00066 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.14560 seconds
Time After: 0.14770 seconds
Time Taken: 0.00210 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.15785 seconds
Time After: 0.15802 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.16114 seconds
Time After: 0.16275 seconds
Time Taken: 0.00161 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=71168', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.18453 seconds
Time After: 0.18742 seconds
Time Taken: 0.00290 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
