Time Before: 0.00207 seconds
Time After: 0.00262 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00269 seconds
Time After: 0.00310 seconds
Time Before: 0.00330 seconds
Time After: 0.00351 seconds
Time Before: 0.00436 seconds
Time After: 0.00683 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00356 seconds
Time After: 0.01204 seconds
Time Taken: 0.00847 seconds
Time Before: 0.01409 seconds
Time After: 0.01460 seconds
Time Before: 0.01842 seconds
Time After: 0.01963 seconds
Time Before: 0.01327 seconds
Time After: 0.01987 seconds
Time Taken: 0.00659 seconds
Time Before: 0.02702 seconds
Time After: 0.02768 seconds
Time Taken: 0.00066 seconds
Time Before: 0.03087 seconds
Time After: 0.03224 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.035101890563965
Time Before: 0.03688 seconds
Time After: 0.03706 seconds
Time Before: 0.03954 seconds
Time After: 0.04155 seconds
Time Taken: 0.00201 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=71267', badlocation = 1
Time Before: 0.05891 seconds
Time After: 0.11014 seconds
Time Taken: 0.05123 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.057511806488037 seconds with 9 queries, spending 0.060241937637329 doing MySQL queries and -0.002730131149292 doing PHP things.
