Time Before: 0.01789 seconds
Time After: 0.02441 seconds
Time Taken: 0.00652 seconds
Time Before: 0.02450 seconds
Time After: 0.02638 seconds
Time Taken: 0.00187 seconds
Time Before: 0.02716 seconds
Time After: 0.02732 seconds
Time Before: 0.02814 seconds
Time After: 0.03072 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02739 seconds
Time After: 0.03490 seconds
Time Taken: 0.00751 seconds
Time Before: 0.04190 seconds
Time After: 0.04230 seconds
Time Before: 0.04367 seconds
Time After: 0.04487 seconds
Time Before: 0.04120 seconds
Time After: 0.04510 seconds
Time Taken: 0.00390 seconds
Time Before: 0.08374 seconds
Time After: 0.08391 seconds
Time Before: 0.09946 seconds
Time After: 0.10070 seconds
End call of global.php: 0.10302495956421
Time Before: 0.10743 seconds
Time After: 0.10759 seconds
Time Before: 0.10980 seconds
Time After: 0.11127 seconds
SET lastactivity = 1776891549, location = '/forums/private.php?do=newpm&explain=1&u=71275', badlocation = 1
Time Before: 0.12883 seconds
Time After: 0.12917 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.12751507759094 seconds with 9 queries, spending 0.0095980167388916 doing MySQL queries and 0.11791706085205 doing PHP things.
