Time Before: 0.00238 seconds
Time After: 0.00297 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00307 seconds
Time After: 0.00366 seconds
Time Before: 0.00388 seconds
Time After: 0.00401 seconds
Time Before: 0.00469 seconds
Time After: 0.00728 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00406 seconds
Time After: 0.01069 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01245 seconds
Time After: 0.01281 seconds
Time Before: 0.01533 seconds
Time After: 0.01662 seconds
Time Before: 0.01190 seconds
Time After: 0.01679 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02230 seconds
Time After: 0.02251 seconds
Time Before: 0.02457 seconds
Time After: 0.02585 seconds
End call of global.php: 0.027496099472046
Time Before: 0.02871 seconds
Time After: 0.02983 seconds
Time Taken: 0.00113 seconds
Time Before: 0.03184 seconds
Time After: 0.03331 seconds
SET lastactivity = 1783106971, location = '/forums/private.php?do=newpm&explain=1&u=71346', badlocation = 1
Time Before: 0.04593 seconds
Time After: 0.04630 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.045032978057861 seconds with 9 queries, spending 0.009411096572876 doing MySQL queries and 0.035621881484985 doing PHP things.
