Time Before: 0.03008 seconds
Time After: 0.03578 seconds
Time Taken: 0.00570 seconds
Time Before: 0.03586 seconds
Time After: 0.03628 seconds
Time Before: 0.03659 seconds
Time After: 0.03673 seconds
Time Before: 0.03758 seconds
Time After: 0.04015 seconds
Time Taken: 0.00257 seconds
Time Before: 0.03681 seconds
Time After: 0.04431 seconds
Time Taken: 0.00749 seconds
Time Before: 0.05343 seconds
Time After: 0.05384 seconds
Time Before: 0.05683 seconds
Time After: 0.05802 seconds
Time Before: 0.05266 seconds
Time After: 0.05826 seconds
Time Taken: 0.00560 seconds
Time Before: 0.10563 seconds
Time After: 0.10577 seconds
Time Before: 0.12507 seconds
Time After: 0.12638 seconds
Time Taken: 0.00131 seconds
Time Before: 0.13762 seconds
Time After: 0.13781 seconds
Time Before: 0.14096 seconds
Time After: 0.14317 seconds
Time Taken: 0.00221 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=71356', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.16590 seconds
Time After: 0.16632 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
