Time Before: 0.00131 seconds
Time After: 0.00185 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00192 seconds
Time After: 0.00325 seconds
Time Taken: 0.00134 seconds
Time Before: 0.00362 seconds
Time After: 0.00374 seconds
Time Before: 0.00474 seconds
Time After: 0.00722 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00381 seconds
Time After: 0.01238 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01456 seconds
Time After: 0.01497 seconds
Time Before: 0.01770 seconds
Time After: 0.01904 seconds
Time Before: 0.01379 seconds
Time After: 0.01928 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02564 seconds
Time After: 0.02611 seconds
Time Before: 0.02828 seconds
Time After: 0.02963 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03291 seconds
Time After: 0.03317 seconds
Time Before: 0.03658 seconds
Time After: 0.03806 seconds
UPDATE session SET lastactivity = 1788871600, location = '/forums/private.php?do=newpm&explain=1&u=71543' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05104 seconds
Time After: 0.05162 seconds
Time Taken: 0.00058 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
