Time Before: 0.00200 seconds
Time After: 0.00257 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00267 seconds
Time After: 0.00319 seconds
Time Before: 0.00340 seconds
Time After: 0.00356 seconds
Time Before: 0.00463 seconds
Time After: 0.00919 seconds
Time Taken: 0.00456 seconds
Time Before: 0.00364 seconds
Time After: 0.01261 seconds
Time Taken: 0.00897 seconds
Time Before: 0.01484 seconds
Time After: 0.01523 seconds
Time Before: 0.01769 seconds
Time After: 0.01895 seconds
Time Before: 0.01423 seconds
Time After: 0.01921 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02621 seconds
Time After: 0.02637 seconds
Time Before: 0.02924 seconds
Time After: 0.03049 seconds
End call of global.php: 0.032279968261719
Time Before: 0.03355 seconds
Time After: 0.03372 seconds
Time Before: 0.03570 seconds
Time After: 0.03719 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=71604'
Time Before: 0.05280 seconds
Time After: 0.05314 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.051856994628906 seconds with 9 queries, spending 0.010298013687134 doing MySQL queries and 0.041558980941772 doing PHP things.
