Time Before: 0.02703 seconds
Time After: 0.03554 seconds
Time Taken: 0.00851 seconds
Time Before: 0.03566 seconds
Time After: 0.03624 seconds
Time Taken: 0.00058 seconds
Time Before: 0.03647 seconds
Time After: 0.03664 seconds
Time Before: 0.03741 seconds
Time After: 0.03959 seconds
Time Taken: 0.00218 seconds
Time Before: 0.03671 seconds
Time After: 0.04356 seconds
Time Taken: 0.00685 seconds
Time Before: 0.05309 seconds
Time After: 0.05354 seconds
Time Before: 0.05629 seconds
Time After: 0.05752 seconds
Time Before: 0.05232 seconds
Time After: 0.05776 seconds
Time Taken: 0.00544 seconds
Time Before: 0.09393 seconds
Time After: 0.09409 seconds
Time Before: 0.11084 seconds
Time After: 0.11207 seconds
End call of global.php: 0.11406397819519
Time Before: 0.12093 seconds
Time After: 0.12108 seconds
Time Before: 0.12399 seconds
Time After: 0.12541 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=71662', badlocation = 1
Time Before: 0.14506 seconds
Time After: 0.14537 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.14404392242432 seconds with 9 queries, spending 0.007889986038208 doing MySQL queries and 0.13615393638611 doing PHP things.
