Time Before: 0.00239 seconds
Time After: 0.00295 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00303 seconds
Time After: 0.00363 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00390 seconds
Time After: 0.00407 seconds
Time Before: 0.00499 seconds
Time After: 0.00794 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00415 seconds
Time After: 0.01282 seconds
Time Taken: 0.00867 seconds
Time Before: 0.01484 seconds
Time After: 0.01524 seconds
Time Before: 0.01777 seconds
Time After: 0.01910 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01412 seconds
Time After: 0.01936 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02495 seconds
Time After: 0.02511 seconds
Time Before: 0.02694 seconds
Time After: 0.02825 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.029898881912231
Time Before: 0.03099 seconds
Time After: 0.03115 seconds
Time Before: 0.03354 seconds
Time After: 0.03502 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=71669'
Time Before: 0.04774 seconds
Time After: 0.04804 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.046815872192383 seconds with 9 queries, spending 0.0088534355163574 doing MySQL queries and 0.037962436676025 doing PHP things.
