Time Before: 0.00454 seconds
Time After: 0.00510 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00521 seconds
Time After: 0.00578 seconds
Time Before: 0.00615 seconds
Time After: 0.00644 seconds
Time Before: 0.00714 seconds
Time After: 0.00919 seconds
Time Taken: 0.00205 seconds
Time Before: 0.00650 seconds
Time After: 0.01260 seconds
Time Taken: 0.00610 seconds
Time Before: 0.01434 seconds
Time After: 0.01472 seconds
Time Before: 0.01704 seconds
Time After: 0.01829 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01379 seconds
Time After: 0.01853 seconds
Time Taken: 0.00475 seconds
Memory After: 2,261.836 KB
Time Before: 0.02446 seconds
Time After: 0.02462 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02762 seconds
Time After: 0.02887 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.03049898147583
Time Before: 0.03175 seconds
Time After: 0.03191 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03394 seconds
Time After: 0.03538 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789078997, location = '/forums/private.php?do=newpm&explain=1&u=71678'
Time Before: 0.04784 seconds
Time After: 0.04813 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.046930074691772 seconds with 9 queries, spending 0.0078210830688477 doing MySQL queries and 0.039108991622925 doing PHP things.
