Time Before: 0.00134 seconds
Time After: 0.00189 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00196 seconds
Time After: 0.00237 seconds
Time Before: 0.00256 seconds
Time After: 0.00269 seconds
Time Before: 0.00332 seconds
Time After: 0.00588 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00273 seconds
Time After: 0.00934 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01112 seconds
Time After: 0.01148 seconds
Time Before: 0.01385 seconds
Time After: 0.01505 seconds
Time Before: 0.01060 seconds
Time After: 0.01522 seconds
Time Taken: 0.00462 seconds
Time Before: 0.02038 seconds
Time After: 0.02053 seconds
Time Before: 0.02232 seconds
Time After: 0.02352 seconds
End call of global.php: 0.025110960006714
Time Before: 0.02626 seconds
Time After: 0.02638 seconds
Time Before: 0.02826 seconds
Time After: 0.02965 seconds
Time Taken: 0.00138 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=71767', badlocation = 1
Time Before: 0.04366 seconds
Time After: 0.04412 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.042769908905029 seconds with 9 queries, spending 0.0079889297485352 doing MySQL queries and 0.034780979156494 doing PHP things.
