Time Before: 0.00186 seconds
Time After: 0.00249 seconds
Time Taken: 0.00063 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00259 seconds
Time After: 0.00303 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00337 seconds
Time After: 0.00353 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00443 seconds
Time After: 0.00718 seconds
Time Taken: 0.00274 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00360 seconds
Time After: 0.01089 seconds
Time Taken: 0.00728 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01270 seconds
Time After: 0.01306 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01593 seconds
Time After: 0.01714 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01212 seconds
Time After: 0.01742 seconds
Time Taken: 0.00530 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02431 seconds
Time After: 0.02447 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02709 seconds
Time After: 0.02873 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
Time Before: 0.03294 seconds
Time After: 0.03308 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03708 seconds
Time After: 0.03850 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
UPDATE session SET lastactivity = 1788880083, location = '/forums/private.php?do=newpm&explain=1&u=71862' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05200 seconds
Time After: 0.05237 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
