Time Before: 0.01585 seconds
Time After: 0.02069 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02078 seconds
Time After: 0.02119 seconds
Time Before: 0.02141 seconds
Time After: 0.02154 seconds
Time Before: 0.02237 seconds
Time After: 0.02472 seconds
Time Taken: 0.00235 seconds
Time Before: 0.02159 seconds
Time After: 0.02943 seconds
Time Taken: 0.00784 seconds
Time Before: 0.03500 seconds
Time After: 0.03543 seconds
Time Before: 0.03861 seconds
Time After: 0.03981 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03411 seconds
Time After: 0.04004 seconds
Time Taken: 0.00593 seconds
Memory After: 2,261.719 KB
Time Before: 0.07193 seconds
Time After: 0.07206 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08242 seconds
Time After: 0.08362 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.09146 seconds
Time After: 0.09192 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09500 seconds
Time After: 0.09648 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=72064', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11138 seconds
Time After: 0.11167 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
