Time Before: 0.00919 seconds
Time After: 0.01478 seconds
Time Taken: 0.00559 seconds
Time Before: 0.01489 seconds
Time After: 0.01534 seconds
Time Before: 0.01558 seconds
Time After: 0.01570 seconds
Time Before: 0.01645 seconds
Time After: 0.01875 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01576 seconds
Time After: 0.02301 seconds
Time Taken: 0.00724 seconds
Time Before: 0.03022 seconds
Time After: 0.03065 seconds
Time Before: 0.03321 seconds
Time After: 0.03462 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02937 seconds
Time After: 0.03486 seconds
Time Taken: 0.00549 seconds
Memory After: 2,261.719 KB
Time Before: 0.04829 seconds
Time After: 0.04851 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05984 seconds
Time After: 0.06109 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.063532114028931
Time Before: 0.06859 seconds
Time After: 0.06881 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07272 seconds
Time After: 0.07425 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=72234'
Time Before: 0.09085 seconds
Time After: 0.09127 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.089392185211182 seconds with 9 queries, spending 0.0083432197570801 doing MySQL queries and 0.081048965454102 doing PHP things.
