Time Before: 0.01998 seconds
Time After: 0.02666 seconds
Time Taken: 0.00668 seconds
Time Before: 0.02675 seconds
Time After: 0.02726 seconds
Time Before: 0.02752 seconds
Time After: 0.02773 seconds
Time Before: 0.02853 seconds
Time After: 0.03220 seconds
Time Taken: 0.00367 seconds
Time Before: 0.02779 seconds
Time After: 0.03717 seconds
Time Taken: 0.00938 seconds
Time Before: 0.04555 seconds
Time After: 0.04577 seconds
Time Before: 0.04870 seconds
Time After: 0.04992 seconds
Time Before: 0.04475 seconds
Time After: 0.05017 seconds
Time Taken: 0.00542 seconds
Time Before: 0.08145 seconds
Time After: 0.08161 seconds
Time Before: 0.10677 seconds
Time After: 0.10803 seconds
End call of global.php: 0.10995888710022
Time Before: 0.11853 seconds
Time After: 0.11870 seconds
Time Before: 0.12121 seconds
Time After: 0.12267 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=72405', badlocation = 1
Time Before: 0.14260 seconds
Time After: 0.14288 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.14160799980164 seconds with 9 queries, spending 0.0091676712036133 doing MySQL queries and 0.13244032859802 doing PHP things.
