Time Before: 0.00142 seconds
Time After: 0.00190 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00197 seconds
Time After: 0.00266 seconds
Time Taken: 0.00069 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00296 seconds
Time After: 0.00335 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00404 seconds
Time After: 0.00636 seconds
Time Taken: 0.00232 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00340 seconds
Time After: 0.01055 seconds
Time Taken: 0.00714 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01245 seconds
Time After: 0.01285 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01534 seconds
Time After: 0.01661 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01177 seconds
Time After: 0.01680 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02207 seconds
Time After: 0.02223 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02416 seconds
Time After: 0.02543 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.027046918869019
Time Before: 0.02838 seconds
Time After: 0.02853 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03050 seconds
Time After: 0.03201 seconds
Time Taken: 0.00152 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1783091139, location = '/forums/private.php?do=newpm&explain=1&u=72409'
Time Before: 0.04449 seconds
Time After: 0.04478 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.043616056442261 seconds with 9 queries, spending 0.0084409713745117 doing MySQL queries and 0.035175085067749 doing PHP things.
