Time Before: 0.00156 seconds
Time After: 0.00209 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00216 seconds
Time After: 0.00272 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00295 seconds
Time After: 0.00308 seconds
Time Before: 0.00381 seconds
Time After: 0.00667 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00313 seconds
Time After: 0.01018 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01203 seconds
Time After: 0.01247 seconds
Time Before: 0.01534 seconds
Time After: 0.01656 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01144 seconds
Time After: 0.01675 seconds
Time Taken: 0.00531 seconds
Memory After: 2,261.719 KB
Time Before: 0.02234 seconds
Time After: 0.02252 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02464 seconds
Time After: 0.02615 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.02972 seconds
Time After: 0.02986 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03244 seconds
Time After: 0.03531 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=72704', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04812 seconds
Time After: 0.04860 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
