Time Before: 0.01473 seconds
Time After: 0.02307 seconds
Time Taken: 0.00834 seconds
Time Before: 0.02319 seconds
Time After: 0.02369 seconds
Time Before: 0.02400 seconds
Time After: 0.02416 seconds
Time Before: 0.02509 seconds
Time After: 0.02800 seconds
Time Taken: 0.00291 seconds
Time Before: 0.02424 seconds
Time After: 0.03166 seconds
Time Taken: 0.00742 seconds
Time Before: 0.04017 seconds
Time After: 0.04055 seconds
Time Before: 0.04199 seconds
Time After: 0.04326 seconds
Time Before: 0.03942 seconds
Time After: 0.04351 seconds
Time Taken: 0.00409 seconds
Time Before: 0.06375 seconds
Time After: 0.06391 seconds
Time Before: 0.08091 seconds
Time After: 0.08219 seconds
End call of global.php: 0.084429979324341
Time Before: 0.09172 seconds
Time After: 0.09191 seconds
Time Before: 0.09429 seconds
Time After: 0.09576 seconds
SET lastactivity = 1776789061, location = '/forums/private.php?do=newpm&explain=1&u=72759'
Time Before: 0.11458 seconds
Time After: 0.11490 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.11358213424683 seconds with 9 queries, spending 0.0086433887481689 doing MySQL queries and 0.10493874549866 doing PHP things.
