Time Before: 0.00143 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00244 seconds
Time Before: 0.00267 seconds
Time After: 0.00311 seconds
Time Before: 0.00404 seconds
Time After: 0.00659 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00320 seconds
Time After: 0.00997 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01179 seconds
Time After: 0.01214 seconds
Time Before: 0.01446 seconds
Time After: 0.01560 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01121 seconds
Time After: 0.01577 seconds
Time Taken: 0.00456 seconds
Time Before: 0.02101 seconds
Time After: 0.02114 seconds
Time Before: 0.02325 seconds
Time After: 0.02455 seconds
Time Before: 0.02872 seconds
Time After: 0.02893 seconds
Time Before: 0.03115 seconds
Time After: 0.03257 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=72775' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04557 seconds
Time After: 0.04586 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
