Time Before: 0.00957 seconds
Time After: 0.01300 seconds
Time Taken: 0.00343 seconds
Time Before: 0.01312 seconds
Time After: 0.01344 seconds
Time Before: 0.01363 seconds
Time After: 0.01373 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01441 seconds
Time After: 0.01659 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01380 seconds
Time After: 0.02099 seconds
Time Taken: 0.00719 seconds
Time Before: 0.02664 seconds
Time After: 0.02750 seconds
Time Taken: 0.00086 seconds
Time Before: 0.02972 seconds
Time After: 0.03093 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02567 seconds
Time After: 0.03119 seconds
Time Taken: 0.00552 seconds
Memory After: 2,261.836 KB
Time Before: 0.04528 seconds
Time After: 0.04540 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05642 seconds
Time After: 0.05760 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.059422016143799
Time Before: 0.06714 seconds
Time After: 0.06726 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06947 seconds
Time After: 0.07088 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789043260, location = '/forums/private.php?do=newpm&explain=1&u=72783', badlocation = 1
Time Before: 0.08833 seconds
Time After: 0.08866 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.087257146835327 seconds with 9 queries, spending 0.0078129768371582 doing MySQL queries and 0.079444169998169 doing PHP things.
