Time Before: 0.01674 seconds
Time After: 0.02289 seconds
Time Taken: 0.00615 seconds
Time Before: 0.02299 seconds
Time After: 0.02345 seconds
Time Before: 0.02368 seconds
Time After: 0.02384 seconds
Time Before: 0.02471 seconds
Time After: 0.02720 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02390 seconds
Time After: 0.03158 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03964 seconds
Time After: 0.04003 seconds
Time Before: 0.04261 seconds
Time After: 0.04385 seconds
Time Before: 0.03898 seconds
Time After: 0.04405 seconds
Time Taken: 0.00507 seconds
Time Before: 0.08042 seconds
Time After: 0.08056 seconds
Time Before: 0.09558 seconds
Time After: 0.09683 seconds
Time Before: 0.10427 seconds
Time After: 0.10443 seconds
Time Before: 0.10687 seconds
Time After: 0.10831 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=72790', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.12844 seconds
Time After: 0.12874 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
