Time Before: 0.00615 seconds
Time After: 0.00848 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00857 seconds
Time After: 0.00902 seconds
Time Before: 0.00939 seconds
Time After: 0.00953 seconds
Time Before: 0.01038 seconds
Time After: 0.01271 seconds
Time Before: 0.00961 seconds
Time After: 0.01761 seconds
Time Taken: 0.00800 seconds
Time Before: 0.02202 seconds
Time After: 0.02240 seconds
Time Before: 0.02495 seconds
Time After: 0.02614 seconds
Time Before: 0.02068 seconds
Time After: 0.02641 seconds
Time Taken: 0.00573 seconds
Time Before: 0.03997 seconds
Time After: 0.04016 seconds
Time Before: 0.04594 seconds
Time After: 0.04719 seconds
End call of global.php: 0.049581050872803
Time Before: 0.05323 seconds
Time After: 0.05337 seconds
Time Before: 0.05609 seconds
Time After: 0.05758 seconds
SET lastactivity = 1789070434, location = '/forums/private.php?do=newpm&explain=1&u=72853', badlocation = 1
Time Before: 0.07307 seconds
Time After: 0.07339 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.072061061859131 seconds with 9 queries, spending 0.0078659057617188 doing MySQL queries and 0.064195156097412 doing PHP things.
