Time Before: 0.00145 seconds
Time After: 0.00193 seconds
Time Before: 0.00201 seconds
Time After: 0.00253 seconds
Time Before: 0.00275 seconds
Time After: 0.00292 seconds
Time Before: 0.00379 seconds
Time After: 0.00614 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00297 seconds
Time After: 0.00952 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01168 seconds
Time After: 0.01218 seconds
Time Before: 0.01524 seconds
Time After: 0.01648 seconds
Time Before: 0.01093 seconds
Time After: 0.01665 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02174 seconds
Time After: 0.02193 seconds
Time Before: 0.02374 seconds
Time After: 0.02498 seconds
End call of global.php: 0.026614904403687
Time Before: 0.02839 seconds
Time After: 0.02861 seconds
Time Before: 0.03115 seconds
Time After: 0.03257 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=73114'
Time Before: 0.04511 seconds
Time After: 0.04559 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044194936752319 seconds with 9 queries, spending 0.0083439350128174 doing MySQL queries and 0.035851001739502 doing PHP things.
