Time Before: 0.00548 seconds
Time After: 0.00772 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00783 seconds
Time After: 0.00831 seconds
Time Before: 0.00857 seconds
Time After: 0.00871 seconds
Time Before: 0.00966 seconds
Time After: 0.01196 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00879 seconds
Time After: 0.01636 seconds
Time Taken: 0.00757 seconds
Time Before: 0.02008 seconds
Time After: 0.02055 seconds
Time Before: 0.02360 seconds
Time After: 0.02484 seconds
Time Before: 0.01945 seconds
Time After: 0.02504 seconds
Time Taken: 0.00558 seconds
Time Before: 0.03631 seconds
Time After: 0.03644 seconds
Time Before: 0.04568 seconds
Time After: 0.04692 seconds
End call of global.php: 0.049443006515503
Time Before: 0.05254 seconds
Time After: 0.05272 seconds
Time Before: 0.05583 seconds
Time After: 0.05727 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=73123'
Time Before: 0.07589 seconds
Time After: 0.07618 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.074643850326538 seconds with 9 queries, spending 0.0079021453857422 doing MySQL queries and 0.066741704940796 doing PHP things.
