Time Before: 0.02610 seconds
Time After: 0.03131 seconds
Time Taken: 0.00520 seconds
Time Before: 0.03138 seconds
Time After: 0.03184 seconds
Time Before: 0.03209 seconds
Time After: 0.03230 seconds
Time Before: 0.03307 seconds
Time After: 0.03553 seconds
Time Taken: 0.00245 seconds
Time Before: 0.03238 seconds
Time After: 0.03964 seconds
Time Taken: 0.00726 seconds
Time Before: 0.04791 seconds
Time After: 0.04833 seconds
Time Before: 0.05071 seconds
Time After: 0.05194 seconds
Time Before: 0.04717 seconds
Time After: 0.05224 seconds
Time Taken: 0.00507 seconds
Time Before: 0.09567 seconds
Time After: 0.09583 seconds
Time Before: 0.11478 seconds
Time After: 0.11604 seconds
End call of global.php: 0.11816811561584
Time Before: 0.12758 seconds
Time After: 0.12779 seconds
Time Before: 0.13031 seconds
Time After: 0.13181 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1776970973, location = '/forums/private.php?do=newpm&explain=1&u=73160', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.15270 seconds
Time After: 0.15297 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.15137910842896 seconds with 9 queries, spending 0.0081498622894287 doing MySQL queries and 0.14322924613953 doing PHP things.
