Time Before: 0.00973 seconds
Time After: 0.01313 seconds
Time Taken: 0.00339 seconds
Time Before: 0.01322 seconds
Time After: 0.01369 seconds
Time Before: 0.01393 seconds
Time After: 0.01410 seconds
Time Before: 0.01493 seconds
Time After: 0.01697 seconds
Time Taken: 0.00205 seconds
Time Before: 0.01415 seconds
Time After: 0.02093 seconds
Time Taken: 0.00678 seconds
Time Before: 0.02810 seconds
Time After: 0.02878 seconds
Time Taken: 0.00067 seconds
Time Before: 0.03191 seconds
Time After: 0.03316 seconds
Time Before: 0.02723 seconds
Time After: 0.03336 seconds
Time Taken: 0.00613 seconds
Time Before: 0.04793 seconds
Time After: 0.04810 seconds
Time Before: 0.05818 seconds
Time After: 0.05948 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.062478065490723
Time Before: 0.06805 seconds
Time After: 0.06822 seconds
Time Before: 0.07061 seconds
Time After: 0.07206 seconds
SET lastactivity = 1788935578, location = '/forums/private.php?do=newpm&explain=1&u=73176', badlocation = 1
Time Before: 0.09066 seconds
Time After: 0.09098 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.089673042297363 seconds with 9 queries, spending 0.0080184936523438 doing MySQL queries and 0.08165454864502 doing PHP things.
