Time Before: 0.00257 seconds
Time After: 0.00350 seconds
Time Taken: 0.00093 seconds
Time Before: 0.00361 seconds
Time After: 0.00404 seconds
Time Before: 0.00431 seconds
Time After: 0.00444 seconds
Time Before: 0.00529 seconds
Time After: 0.00835 seconds
Time Taken: 0.00306 seconds
Time Before: 0.00450 seconds
Time After: 0.01179 seconds
Time Taken: 0.00730 seconds
Time Before: 0.01372 seconds
Time After: 0.01414 seconds
Time Before: 0.01678 seconds
Time After: 0.01817 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01312 seconds
Time After: 0.01841 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02469 seconds
Time After: 0.02483 seconds
Time Before: 0.02912 seconds
Time After: 0.03038 seconds
End call of global.php: 0.032006978988647
Time Before: 0.03339 seconds
Time After: 0.03356 seconds
Time Before: 0.03566 seconds
Time After: 0.03714 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=73305'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05136 seconds
Time After: 0.05175 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.050211906433105 seconds with 9 queries, spending 0.0088868141174316 doing MySQL queries and 0.041325092315674 doing PHP things.
