Time Before: 0.02485 seconds
Time After: 0.03018 seconds
Time Taken: 0.00533 seconds
Time Before: 0.03025 seconds
Time After: 0.03066 seconds
Time Before: 0.03094 seconds
Time After: 0.03108 seconds
Time Before: 0.03199 seconds
Time After: 0.03468 seconds
Time Taken: 0.00270 seconds
Time Before: 0.03116 seconds
Time After: 0.03850 seconds
Time Taken: 0.00734 seconds
Time Before: 0.04726 seconds
Time After: 0.04763 seconds
Time Before: 0.05017 seconds
Time After: 0.05140 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04657 seconds
Time After: 0.05159 seconds
Time Taken: 0.00502 seconds
Memory After: 2,261.719 KB
Time Before: 0.09408 seconds
Time After: 0.09447 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11236 seconds
Time After: 0.11360 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.12254 seconds
Time After: 0.12293 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12510 seconds
Time After: 0.12661 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=73436' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14447 seconds
Time After: 0.14480 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
