Time Before: 0.00141 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00239 seconds
Time Before: 0.00290 seconds
Time After: 0.00338 seconds
Time Before: 0.00403 seconds
Time After: 0.00729 seconds
Time Taken: 0.00326 seconds
Time Before: 0.00343 seconds
Time After: 0.01260 seconds
Time Taken: 0.00918 seconds
Time Before: 0.01464 seconds
Time After: 0.01505 seconds
Time Before: 0.01694 seconds
Time After: 0.01814 seconds
Time Before: 0.01399 seconds
Time After: 0.01834 seconds
Time Taken: 0.00435 seconds
Time Before: 0.02336 seconds
Time After: 0.02350 seconds
Time Before: 0.02542 seconds
Time After: 0.02672 seconds
Time Before: 0.02954 seconds
Time After: 0.02971 seconds
Time Before: 0.03228 seconds
Time After: 0.03387 seconds
Time Taken: 0.00159 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=73603', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04692 seconds
Time After: 0.04715 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
