Time Before: 0.00241 seconds
Time After: 0.00296 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00308 seconds
Time After: 0.00364 seconds
Time Before: 0.00387 seconds
Time After: 0.00401 seconds
Time Before: 0.00490 seconds
Time After: 0.00781 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00410 seconds
Time After: 0.01300 seconds
Time Taken: 0.00890 seconds
Time Before: 0.01490 seconds
Time After: 0.01534 seconds
Time Before: 0.01846 seconds
Time After: 0.01967 seconds
Time Before: 0.01428 seconds
Time After: 0.01992 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02547 seconds
Time After: 0.02564 seconds
Time Before: 0.02977 seconds
Time After: 0.03105 seconds
Time Before: 0.03565 seconds
Time After: 0.03581 seconds
Time Before: 0.03802 seconds
Time After: 0.03954 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=73688', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05239 seconds
Time After: 0.05265 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
