Time Before: 0.00191 seconds
Time After: 0.00317 seconds
Time Before: 0.00328 seconds
Time After: 0.00454 seconds
Time Before: 0.00484 seconds
Time After: 0.00499 seconds
Time Before: 0.00568 seconds
Time After: 0.00923 seconds
Time Taken: 0.00355 seconds
Time Before: 0.00505 seconds
Time After: 0.01265 seconds
Time Taken: 0.00761 seconds
Time Before: 0.01476 seconds
Time After: 0.01516 seconds
Time Before: 0.01779 seconds
Time After: 0.01910 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01405 seconds
Time After: 0.01935 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02703 seconds
Time After: 0.02720 seconds
Time Before: 0.45164 seconds
Time After: 0.45359 seconds
Time Taken: 0.00195 seconds
End call of global.php: 0.45620703697205
Time Before: 0.46269 seconds
Time After: 0.46283 seconds
Time Before: 0.46549 seconds
Time After: 0.46916 seconds
Time Taken: 0.00366 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=73712'
Time Before: 0.48630 seconds
Time After: 0.48647 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.48531484603882 seconds with 9 queries, spending 0.012773752212524 doing MySQL queries and 0.47254109382629 doing PHP things.
