Time Before: 0.02549 seconds
Time After: 0.03323 seconds
Time Taken: 0.00774 seconds
Time Before: 0.03333 seconds
Time After: 0.03399 seconds
Time Taken: 0.00066 seconds
Time Before: 0.03433 seconds
Time After: 0.03453 seconds
Time Before: 0.03544 seconds
Time After: 0.03774 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03461 seconds
Time After: 0.04331 seconds
Time Taken: 0.00870 seconds
Time Before: 0.05131 seconds
Time After: 0.05151 seconds
Time Before: 0.05400 seconds
Time After: 0.05522 seconds
Time Before: 0.05064 seconds
Time After: 0.05544 seconds
Time Taken: 0.00480 seconds
Time Before: 0.10781 seconds
Time After: 0.10800 seconds
Time Before: 0.18624 seconds
Time After: 0.18749 seconds
Time Before: 0.19802 seconds
Time After: 0.19821 seconds
Time Before: 0.20053 seconds
Time After: 0.20205 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1783094460, location = '/forums/private.php?do=newpm&explain=1&u=73731' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.22218 seconds
Time After: 0.22250 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
